TrailBlazer 2002-2009
Road noise(?) when turning right
Old August 3rd, 2011, 2:09 PM
cbenslay's Avatar
Default Road noise(?) when turning right
My 2005 Trailblazer is making noise when turning to the right. I thought it was just tire/road noise, but it is getting louder and louder. It makes the noise a little when going straight or a little right pressure on the wheel. However, when turning left the noise is gone.
I recently had new front shocks or struts put on by a friend who is a mechanic at a local Cadillac dealership. I don't know if the issue is related or not. My wife drives the Trailblazer 99% of the time...
Wheel bearing?
Thanks,
Old August 3rd, 2011, 8:02 PM
EinST's Avatar
Welcome to the forum. Symptoms like that are usually from wheel bearings. Perhaps injudicious use of big hammers or air guns by the mechanic is the cause. Hopefully he didn't let the brake calipers hang by the hose as well (a little peeve of mine).
Old August 4th, 2011, 12:35 PM
Official GM Rep
cbenslay,
I am sorry to hear that you are experiencing this issue. Have you been back to that Cadillac dealership to let them know you are now experiencing an issue after your current service visit?
Thank you,
Elizabeth, Chevrolet Customer Service
Old August 4th, 2011, 8:08 PM
cbenslay's Avatar
I have not been back yet because I did not know if it was related since that repair was a few months ago...
Can you respond to my other question here? https://chevroletforum.com/forum/sil...esistor-44429/
Thanks!
Chuck
Old August 4th, 2011, 8:59 PM
MDTAHOE's Avatar
Shounds like a bad bearing. Most likely has nothing to do with previous repair
Old August 5th, 2011, 3:23 PM
cbenslay's Avatar
I didn't think so either. Thanks!
Old August 6th, 2011, 11:30 AM
cbenslay's Avatar
Default Which wheel bearing?
OK, if the noise is there when I am turning right then it is the left wheel bearing that is bad, correct? It seems that would be the weight bearing side...
Also, I can't find any replacement info on here. Am I missing it somewhere?
Thanks,
Old December 23rd, 2013, 11:24 AM
BoilerRacingCo's Avatar
Default Wheel bearing repair
Okay, this is an old thread, but for those who are still reading on front wheel noise...
My front passenger side wheel bearing went bad. I knew it was the passenger side wheel bearing because when it first started making a grinding noise, it worsened as I turned left and went away when I turned right. Over time it got louder and when turning left or right made less of a difference on the noise, I new it was past time to replace. I changed the part in my garage in a few hours with a part from the local big box auto store.
Hope this helps someone who is currently digging for answers
Old December 23rd, 2013, 11:33 AM
Welcome to the forum..
Thanks for following up on the thread, it may be stale but your are correct, it may help someone searching for an answer...
2004K2500
September 17th, 2015 4:33 PM
dhoff024
October 28th, 2014 2:57 PM
OntheRoadAgain
April 17th, 2012 1:03 PM
kershawa
January 15th, 2010 6:38 PM
JasonT
October 6th, 2009 10:56 AM
Quick Reply: Road noise(?) when turning right
