rubbing noise when turning left
Old October 7th, 2011, 8:30 AM
  #11
momofsix's Avatar
Default Momofsix
Big Daddy did you ever find a solution to the rubbing/groaning noise in the steering column?? I'm desperately looking for a "do it yourself" solution.
Thanks!
Old October 13th, 2011, 8:39 AM
  #12
Bigdaddy95's Avatar
Actually,
no, have not found solution yet.
Tried everything that was suggested.
Thinking of changing out pw steering pump.
please let me know if you find a fix.
thanks,
Bigdaddy
Old October 15th, 2011, 12:57 PM
  #13
daryl's Avatar
Mine was doing it and power steering fluid was low.
Old April 27th, 2012, 9:54 AM
  #14
New User
Awaiting E-mail Confirmation
luvmystang67's Avatar
I think I know the exact sound and I have come to the conclusion that it must be the intermediate steering shaft, based on where the sound comes from and the overall reliability of the rest of the vehicle. Check out this link... there are updated parts to fix this. Looks like about $95 from GM Parts Direct, 1 hr of your time and 2 bolts.
http://www.hotspotoutdoors.<wbr>com/forum/ubbthreads.php/<wbr>topics/2396348/2004_Silverado_<wbr>Intermediate_St
Good Luck!
Old October 14th, 2012, 11:53 PM
  #15
Silverado Christian's Avatar
Default Left turn squeal
I need help!! When I turn my truck to the left to make a full turn it squeals like a pig. It sounds like its coming from the area of the left wheel. I think it's only when the truck is cold. Any ideas??
Old October 15th, 2012, 6:23 AM
  #16
pegrizz's Avatar
My '05 used to do that. Seems to have stopped since I had my 4WD go out and had the transfer case and actuator replaced. Hope that's not your problem.
Old October 16th, 2012, 2:23 PM
  #17
Official GM Rep
Silverado Christian,
What model year is your vehicle? Have you had any luck in getting this addressed since your post?
Sarah (Assisting Louis), Chevrolet Customer Service
Old October 16th, 2012, 11:13 PM
  #18
My truck is a 2006 2500hd silverado. When the truck is cold (been sitting for a few hours) and I make a left turn onto a street, it squeals. The sound is either quiet or loud. Sounds like a pig is under my wheel. I took the tire off and sprayed silicon spray on the all rubber parts. Helped a little but noise is still there. Any ideas?? I have a new 1 year old steering pump and fluid is full
Old August 30th, 2017, 1:42 AM
  #19
Tony Lucas's Avatar
Originally Posted by Bigdaddy95
Actually,
thanks,
Bigdaddy
did you ever find a fix for this issue im trying to find out what going on with my girls truck so i can fix it
Old September 3rd, 2020, 5:50 PM
  #20
cdot's Avatar
Default Check this first.
Greetings !
I have a 2004 silverado 1500 ext. cab./ 85k
When turning left, at a slow speed, I hear a rubbing noise, (rubber?) and feel a slight vibration in the steering wheel.
no clunks or bangs like I've read about.
Steers fine, back roads, and hwy.
P/S fluid is full.....no leaks underneath.
serpentine belt is tight.
Can anyone out there guide me in the right direction please ?
Would like to do this repair myself.
Thank-you in advance.
Bigdaddy
If you look under driver side dash, on the floor close to the firewall, you will see where the steering shaft travels through the cab into the engine bay. There is a rubber seal from the floor, around the steering shaft. Use some form of spray silicone lubricant at the top of this rubber seal and allow silicone lubricant to travel down into the seal. That should stop the rubber sounding squeak when turning your steering wheel.
2500hdbeast
February 16th, 2015 8:22 PM
jglm77
10
February 17th, 2014 9:39 PM
JasonT
October 6th, 2009 10:56 AM
jla74
April 7th, 2009 8:08 PM
julio
October 17th, 2007 6:05 PM
Quick Reply: rubbing noise when turning left
