2003 Suburban Driver Window issue
Old August 20th, 2011, 3:17 PM
chunk_le_funk's Avatar
Default 2003 Suburban Driver Window issue
For about a year our 2003 Suburban had driver window issues. when pressing the button to roll up the window it would stop 1/2 way then you would have to wait about 30 seconds press he button again for the window to roll up.
Now it has completely stopped working. The other windows work fine.
Is it just the motor or do you have to replace the whole assembly?
Old August 21st, 2011, 11:21 AM
frogg's Avatar
If it is the regulator, you replace the whole assembly. Cost from $45-$100+ for the part. Take a look at this How To Remove Door Panels On A 2002 Chevy Suburban - 2000 to 2007 Model Years to see how to remove door panels on your suburban to decide if you want to do it your self. There are tutorials online for actual replacement of the the regulator. But it could just be the switch, or a wiring problem, so I would troubleshoot that first.
Old August 21st, 2011, 12:57 PM
kevinkpk's Avatar
Probably just the motor. Since you have to pull the panel, it is easy to check.
markwemple
September 3rd, 2015 10:16 AM
Schroeder
May 28th, 2015 8:32 PM
rafter
Express & G-Series Vans
September 1st, 2014 9:17 AM
Victory
February 8th, 2010 9:55 AM
atkipauw
December 22nd, 2009 2:02 PM
Quick Reply: 2003 Suburban Driver Window issue
