Misfire? Running rough around 50 mph and 12 to 1500 rpm?
Old September 27th, 2011, 6:24 PM
kronzy's Avatar
Default Misfire? Running rough around 50 mph and 12 to 1500 rpm?
My 2001, 150000 miles, Sub just started running a bit rough, possibly a misfire, but not sure? Around 45 to 50 mph, 1200 to 1500 rpm, most pronounced going uphill, engine seems to skip, run rough, misfire?, If i downshift it doesn't seem to do it? Normal idle and low speed, smooth running. There isn't any check engine light on. I thought about plugs and new wires, but some of the stuff I have read here doesn't really back that up as a solution. Possibly and O2 sensor although I thought I would get a check engine light for something.
Does anyone have any thoughts or recommendations before spending a $1000 with mechanic checking things of the list. Thanks in advance for any help!!
Old September 28th, 2011, 12:16 PM
RacerX's Avatar
may be a pending code in the computer...scan to see.
Old September 28th, 2011, 8:35 PM
2001, 150K miles I'd start with a good clean tune up...run a few bottles of injector cleaner, check the fuel pressure... clean up the MAF sensor...
Old October 3rd, 2011, 10:58 AM
slw210's Avatar
Hook up a vacuum gauge and read THIS.
Old October 3rd, 2011, 7:07 PM
loosebearing's Avatar
More pronounced going up hill... might be the catalyst stopped up.
Old April 14th, 2013, 8:48 AM
hoghunter03's Avatar
My 2005 z71 does the same thing except hills don't seem to affect it
Old April 18th, 2013, 8:37 PM
Joe In NY's Avatar
ummm yeah. you got clogged cats if you have zero vacuum....
Schooner
June 20th, 2014 9:37 PM
85fordyota
Express & G-Series Vans
June 27th, 2013 11:26 PM
alamozgreat
August 17th, 2011 11:08 PM
ventureman
July 25th, 2010 4:21 PM
atlbigboi
November 22nd, 2007 9:16 AM
Quick Reply: Misfire? Running rough around 50 mph and 12 to 1500 rpm?
