#7 misfire
#7 misfire
Tahoe started running rough this weekend. Last night the CE light came on and coded for #7misfire. I swapped out the coil pack with #1 and reset the light. This afternoon the CE light came back on, again misfire #7. Is this a spark plug and wire issue or is there something else I can check?
All wires and plugs were changed less than 25k miles.
I would walk all three items to the opposite side of the engine.... but yes it could be a plug and or wire....might try running some injector cleaner thru also..
did you replace them with OEM or aftermarket plugs wires?
replaced #7 spark plug and let it idle for about 5 mins. so far no misfire. This is what the old spark plug looked like after 23k miles. Is this caused by excessive oil consumption?
akimber
14
August 22nd, 2006 11:45 AM
