2001 suburban 2500 which fuel pump
Old October 29th, 2011, 8:27 AM
hedinj's Avatar
Default 2001 suburban 2500 which fuel pump
I have a 2001 suburban 2500 4x4 and need to replace the fuel pump. There are two listed. Does anyone know how to tell by the VIN # which pump is required? also, any recommendation on brands to use?
Old October 29th, 2011, 9:42 PM
MDTAHOE's Avatar
Any good parts store should be able to tell you buy the vin, not a big box chain store. Only use a AC Delco or Delphi pump anything else will fail quickly
Old October 31st, 2011, 8:01 PM
kirkgrau's Avatar
The 2500's have a pretty convoluted fuel system. Actually have 2 tanks although there is no manual switching between them, they function as a single tank. Fill goes to rear (secondary) tank where it is transferred by secondary fuel unit to front (primary) tank. If you are able to utilize the entire 38.5 gallon volume of the system you probably need the front (primary) pump.
Have a leak somewhere in mine and have not had time to crawl under it to find it (doesn't help that it seems to be either raining or even snowing when I have some time to inspect it).
Good Luck,
Kirk
Old August 1st, 2016, 3:30 PM
hayden427@gmail.com's Avatar
Default Explains a lot...
I was driving through northern Arizona/New Mexico and got down to just under of half a tank and it started cutting out on me . Luckily I rolled past the only gas station in 100 miles and filled it up. Ran fine after that. Sounds like the rear transfer pump is failing from the sound of it. Just have to keep it above half tank until I get home...
silverado 1500 2001
September 3rd, 2014 1:03 PM
lostinthewoods
Express & G-Series Vans
May 8th, 2014 12:19 AM
hunter10220
May 18th, 2011 8:37 PM
rif
June 13th, 2007 9:12 AM
BinkysDad
October 24th, 2006 11:32 PM
Quick Reply: 2001 suburban 2500 which fuel pump
