Humming noise from rear end, 2000 Tahoe
Old November 22nd, 2011, 1:26 AM
Chevy15379's Avatar
Default Humming noise from rear end, 2000 Tahoe
I have an annoying humming noise coming from the rear end of my tahoe. It sounds like a school bus constantling humming/howling. its a 2 wheel drive automatic. I recently changed the fluid in the rear differential which was almost a quart low but that didnt change anything. I figured the noise is coming from the differential because when I pop the shifter in neutral it immediately stops. But when im driving and its making the noise i can swerved to the right and it goes away, or if im on a road that has a right curve itll go away while im turning too. Just wondering if anyone has had this happen before
I would think wheel bearings because of it going away while i turn, but the fact that it goes away when i put it in neutral is weird
Old January 5th, 2012, 4:10 PM
shonoff83's Avatar
Cool rear end noise
i'm having that exact problem with my truck,i got an 2001 suburban 1500,2wd.. when i'm driving it makes an annoying humming sound,when i got off the gas,it stops... i was told that it may be the pionion rings in the rear,but i really wanna get it fixed a.s.a.p,because it's making me so frustrated with the truck... the previous owner obviously didn't take good care of the truck....when i find out exactly of the problem,i will let you know.... shonoff83@yahoo.com
Old January 5th, 2012, 4:11 PM
shonoff83's Avatar
also,my truck has 166k on the dash....
custom_car_man87
January 27th, 2015 1:07 PM
98chevymonte
January 8th, 2013 7:59 AM
Mr.Cale
January 15th, 2012 5:39 PM
TASpinney9110
March 15th, 2011 5:54 PM
gmck
May 5th, 2010 8:58 PM
Quick Reply: Humming noise from rear end, 2000 Tahoe
