Low beams stopped working but high beams do work. Fuses still good
I have a 2008 two door chevy cobolt sport.
My low beams stopped working. The high beams work and all other lights work. The fuses are still good.
I have been unable to trouble shoot the issue on my own.
Anyone have an idea of where the trouble is at?
Official GM Rep
on
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> It sounds like your low beams may have burnt out. Low beams are used more; therefore they burn out before high beams. The high beams and low beams are usually either separate bulbs or filaments. If you are still under warranty, swing by the dealer and have them replace them for you. If you have any additional questions, feel free to contact me.
Louis
GM Customer Service
Louis
GM Customer Service
I'm sure the demographics has something to do with it but sometimes it's a crapshoot with the Cobalt. A buddy of mine once told me that he finds surprises plenty in them. Has there been any modifications to the vehicle? Do the low beams work as DRL?
Repair complete
The low beam filaments were burned out. Thank you for the assistance.
This vehicle has no modifications to its design. I have considered doing it but cannot afford it atm. I am not sure what you mean by DRL as I am bit of a novice when it comes to automotive.
Grandson had both low beams burn out at the same time. Looked at the low beam fuses and the relay. Like you I've never seen both burn out at the same time.
2008 Chevy Impala
My low beams not work at all now, but my high beam works good, Do I have to take the whole Front of the car to fix it??
I have the same problem (left side low beam fail while right one works well) and what even curious is the high beam does not work when I push forward the light control handle but work when I pull backward (i.e., I must hold it at this position if I want high beam work).
Louis
GM Customer Service
Louis
GM Customer Service
