2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2003 Impala Headlights turn off without warning
Old January 3rd, 2012, 7:29 PM
My3boys's Avatar
Default 2003 Impala Headlights turn off without warning
About 3 weeks ago, one night the headlights went out while driving down the road. In a state of panic, turned on, pushed in all *****/switches and somehow the headlights came back on. Tonight as I was taking my son to karate, the same thing happened. This time pulled the headlight switch out and they came on, pushed the headlight switch back in and they stayed on like they were suppose to. 10 seconds later, they went off again. Could not get them to come back on this time. The fog lights and parking lights work. Does anyone have any suggestions as to what might be causing this?
Old January 5th, 2012, 1:57 PM
Impala Super Moderator
HotSauce6226's Avatar
I think I know your issue. Ill wait and see if you reply
Old January 5th, 2012, 7:47 PM
My3boys's Avatar
ok. So what do you think the issue is?
Old January 5th, 2012, 8:27 PM
Are the headlights just turning off with no warning?
If so check the grounding wire under the hood to the left of the drivers headlight. Let me find a picture. If that wire isnt connected good, it will cause the lights to turn off.
Old January 10th, 2012, 2:38 AM
jim2706's Avatar
I have the same problem on an 04 impala any other.thoughts if the ground is not the problem
Old May 12th, 2016, 3:07 PM
jorenima's Avatar
I have the same problem as well in an 01 Impala. I had another light issue which was that the turn signals and hazards would work then not work. If anyone else has that issue have the hazard button replaced if its not one of the two fuses required to operate them.
kirks22m
April 18th, 2014 12:22 PM
netmessys
Equinox
January 19th, 2012 2:37 PM
Mr. Vann
November 25th, 2009 7:24 PM
jffgin
February 2nd, 2008 6:45 PM
r970
June 3rd, 2007 8:16 AM
Quick Reply: 2003 Impala Headlights turn off without warning
