2007 Silverado Dash Light?
I have a 2007 Silverado Classic 1500 Crew Cab. Only the right side of the stereo lights work and the climate control lights don't work at all. Any ideas?
Official GM Rep
on
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> bmedlock,
Does the radio and climate control still work? Have you checked the fuses? Bulbs?
Louis
GM Customer Service
Louis
GM Customer Service
The radio and climate control both still work. I checked the fuses and they are all good. I pulled the radio and the climate control out to check the bulbs but i'm not sure how to get to the bulbs. Is there an easy way to take them apart to check the bulbs?
There are no user-serviceable bulbs (LEDs actually) in them. They usually outlast the device they are found in but do burn out or their driver circuitry do from voltage spikes. They are tied to the instrumentation illumination (not to be confused with the courtesy lighting) and thus it could be a wiring issue. If it's important to you, consider a visit to the service department.
scottan1
October 3rd, 2017 12:04 AM
ToTo
January 22nd, 2015 2:11 PM
whitesox1933
July 28th, 2012 8:13 PM
Reaper22
June 19th, 2012 10:41 AM
biglg
December 3rd, 2006 11:21 PM
