'83 Suburban barn doors won't open
Old March 5th, 2012, 7:27 PM
Autonerd's Avatar
Default '83 Suburban barn doors won't open
Hi all --
I just bought an '83 Suburban, and the barn doors won't open. Pushing the button does nothing.
Because the doors are closed, I can't get the interior panels all the way off. Through one access hole, I can see the mechanism; there's a flat plate that tips fore and aft, with rods going to (I assume) the upper and lower latches. The rod to the lower is detached, but I don't know if this is the cause or a result of my problem.
I can slide the plate up and down and rotate it on its axis, but not enough to get the door latches to open -- don't know if that's because it's jammed or my dainty little fingers just aren't strong enough.
I can see a bit of the latch at the top of the door, the lower one is difficult to get to.
Any trick to opening the doors without a working handle? I'm hoping that if I can get them open, I can get better access to the mechanism to change or fix it.
TIA
Aaron
Old March 5th, 2012, 8:23 PM
Welcome to the forum.
Might check w/ a body shop.
Old March 5th, 2012, 10:43 PM
66impala4dr's Avatar
pull the panel on the back doors and check the button with the cable and the rod see if they fell off. i think it would be the bushing that broke and the rod fell off. there like 9 phillips screws on the panel with the door that has the button on the outside.
gordonf238
December 8th, 2019 12:52 PM
PapaHepcat
September 27th, 2015 10:42 PM
webbyj
April 30th, 2015 6:12 PM
WrenchMonkey73
March 28th, 2013 4:23 PM
mcconcma
September 22nd, 2006 3:19 AM
Quick Reply: '83 Suburban barn doors won't open
