Old July 24th, 2015, 5:52 PM
See related guides and technical advice from our community experts
P0171 system too lean bank 1
Old March 31st, 2012, 9:00 PM
debo's Avatar
Angry P0171 system too lean bank 1
I got this truck like a month ago. After I got it the evap code was on I took it in to the shop it was replaced but it wasn't plugged in so they hooked it up for me its still got a hard start. It takes 3 turns to get it to fire. I've replaced the fuel pressure regulator and plugs and wires and nothin. So now I got p0171 system too lean bank 1. I've clean the maf sensor and 3I days later it came back on
Anyone have this problem?
Old April 1st, 2012, 9:19 AM
nkh34's Avatar
it might need a new sensor also you want to really look at the manifold if its cracked anywhere it will throw this code all day if its not really effecting anything you might also look at the 02 sensor it could just be going out
Old April 1st, 2012, 9:29 AM
debo Welcome to the forum...
What year and engine do you have?
It might be worth checking the fuel pressure as well.... and as nkh34 suggested check for any vacuum leaks...
Old January 6th, 2015, 11:00 PM
99 tahoe 5.7 vortec's Avatar
Need help have a p0171 code comes on only at night I clear the code and drive all day and Nothing it only comes on at night checked intake for leaks mass air clean new plugs wires cap rotor. What else can I do to make it go off
Old July 8th, 2022, 8:16 AM
paul83814's Avatar
1999 k2500 suburban was throwing p0171 bank 1 lean codes. I chased vacuum leaks as main cause to no avail. Ended up pulling upper intake manifold and replaced fuel injection spider. Problem fixed and runs much better. Before was hard to start and ran rough at all rpm’s. Long term fuel trim was in mid 20s on bank 1. Replaced bad pre cat o2 sensor on bank 1. I waited on replacing the fuel injection because I didn’t have both p0171 and p0174 codes, but apparently only injectors on the left side were partially clogged.
fixingcarsisfun
May 24th, 2015 12:35 PM
jimmydow1
February 17th, 2011 8:12 PM
jimmydow1
February 12th, 2011 12:56 PM
surfandride
January 16th, 2011 10:05 PM
dananarama
Cobalt
December 8th, 2008 1:50 PM
Quick Reply: P0171 system too lean bank 1
