97 vs 98 4wd solenoid difference
Old April 30th, 2012, 1:13 PM
jgray152's Avatar
Default 97 vs 98 4wd solenoid difference
I have a 97 and a 98 silverado. Both are 4wd. Im in the middle of swapping engines but I noticed my 97's solenoid for the 4wd looks tiny and almost nothing compared to my 98's. The 4wd engages very slowly and near silent on the 97 but you can hear a clunk and its quick in my 98 which I like.
Can I swap these solenoids?
97 Silverado Solenoid
98 Silverado Solenoid
Old April 30th, 2012, 6:39 PM
Doug Roberts's Avatar
Yeah you can always try the housinglooks the same but be worned they may not work so u may save now but my wreck your 4x4 later I say buy the right one or at least advance and look part numbers up
Old May 1st, 2012, 3:49 PM
Rez
Rez's Avatar
interesting, my 97 looks like the 2nd pic
Old May 3rd, 2012, 12:36 AM
jgray152's Avatar
Has no one ever seen such a small solenoid on a 97 silverado before?? I am wondering if it came from a different truck and if that's why its not working correctly.
Old May 3rd, 2012, 12:37 AM
jgray152's Avatar
ok well I actually found a picture of it in the link below. seems to be one of the right ones....
1996-1997 Chevrolet K1500 4WD Actuator – Standard TCA-21 - 4WD Actuator - Standard
Old May 3rd, 2012, 12:44 AM
jgray152's Avatar
Is the top one an older thermal design? I read in a post on at the link below that this might be an older design and I could just convert over to the newer design that I like.
1997 Chevrolet K1500 Silverado 4x4 Issues
UPDATED. Ok yes that is an older thermal design. GM had issues with them and replaced them with the electronic design. You can convert it over you just need to either splice in a wire.....somewhere to the sensor above it (no 100% sure which wire yet) or buy the conversion harness at the link below...
The main problem with these older designs seem to be the problem I'm having....VERY SLOW ENGAGEMENT. Gets much worse as the outside temp drops since there is a fluid which gets heated up to allow it to expand and push what ever rod or actuator arm out to engage 4wd
http://www.oreillyauto.com/site/c/de...drive+actuator
Old May 6th, 2012, 5:26 PM
shamrock246's Avatar
looks like mine was upgraded at one time that explanes the brown wire connected to the positive lug next to the fuse box with no fuse on it that i found
RrCoX22
September 27th, 2007 4:14 PM
russo_z
July 13th, 2006 12:40 PM
HEMIkiller
May 27th, 2006 12:43 AM
Chevyman21
Colorado
April 27th, 2006 10:38 PM
Quick Reply: 97 vs 98 4wd solenoid difference
