4l60e slipping
Old May 5th, 2012, 7:11 PM
gaftop1's Avatar
Cool 4l60e slipping
94 c1500 4.3 4l60e
slips going from 1 to 2. will go to 2500 rpm drop to 2000 then shifts to 2 and rpms drop to 1500 . was shifting at 2000 rpm with a drop to 1500 at each gear change . have had a obd1 67 code (tcc code). was shifting fine with some slippage if i tromped on it but i had a new fuel pump installed and now its worse (why). ordered a tcc solenoid hoping it will help.
hope my rambling is understood. any ideas?
Old May 6th, 2012, 1:02 AM
chevyboy1993's Avatar
my 95 slips from first to second bad, goes from 2000 up to 2800 then down to 1500. not throwing any codes though. on my way home today shifting from first to second it did like a skip then shifted to second without rpm's going up. don't know why though
Old May 7th, 2012, 7:16 AM
gaftop1's Avatar
the check engine light won't show that there are codes for this.
you need to jumper the a b terminals of the aldl and read the check engine light blinks. to see if it stored transmission code
Old May 7th, 2012, 1:53 PM
i'll have to look at that. any way to see what code by how many blinks?
Old May 8th, 2012, 8:16 AM
gaftop1's Avatar
jump a b on the aldl turn ignition on. your check engine light will blink.
you'll get a blink a pause and 2 blinks it will repeat 3 times.
the next series is your stored codes. mine was a 6 pause 7 repeated 3 times . when your codes are done the 1 pause 2 will come up again
Old May 9th, 2012, 2:40 PM
gaftop1's Avatar
need a transmission guru??????????
Old May 9th, 2012, 9:40 PM
MDTAHOE's Avatar
You need a new transmission or a rebuild. Once they are slipping "bad" they are done.
Old May 9th, 2012, 9:46 PM
i'm looking at the monster in a box master rebuild kit for my trans because i will be dropping a built 350 into it
abqgolfer
August 27th, 2011 11:30 PM
03BOWTIE
11
June 27th, 2011 9:34 AM
JeffPettit
August 1st, 2008 6:20 PM
BWEST
December 18th, 2005 11:44 PM
Quick Reply: 4l60e slipping
