Obd ii p0430
Old August 28th, 2012, 11:51 AM
Killmo's Avatar
Default Obd ii p0430
Hi, I have a 1998 Chevy 1500 Z71 4WD with the 5.7l throttle body injection that pops the P0430 code every two weeks or so before I clear it, today i just noticed that it showed the same code twice both of which were indicating bank 2 was below efficiency. I was wondering if this means both my upstream and downstream O2 sensors were having issues or there were two problems relating to just one of my O2 sensors. Also, the code wont show up if I add seafoam or lucas oil upper cylinder lubricant for an extra week or two, does it just mean there is extra carbon build up on my sensors from how bad the gas is nowadays with all the ethanol and other additives?
Thanks, Tyler
Old August 28th, 2012, 12:55 PM
kevinkpk's Avatar
It's either the cat, or the downstream O2 sensor. I'd suspect cat.
Old August 28th, 2012, 9:52 PM
MDTAHOE's Avatar
You need a cat. If your truck is a 1998 you do not have throttle body injection (TBI).
Old August 30th, 2012, 11:55 AM
Killmo's Avatar
Okay so its most likely the cat then, nothing im too worried about. Thank you, but any idea why I'd be getting the same code twice? Since the P0430 comes up twice and both say that bank 2 is under efficient.
Old August 30th, 2012, 8:34 PM
MDTAHOE's Avatar
One is probably current and the other pending. Is there a pd in front of one of the po430
Old September 12th, 2012, 10:58 PM
Killmo's Avatar
There is no pd in front of either of them. I just cleared them again today. And now I'll be replacing the radiator in my truck soon...
CableSux
Express & G-Series Vans
10
August 10th, 2017 10:28 PM
bjoern
Computer, Ignition, & Fuel Systems
June 24th, 2011 11:32 AM
Copedawg
February 2nd, 2011 3:50 AM
TCsix
August 19th, 2010 9:12 PM
3647dan
December 1st, 2009 1:06 AM
Quick Reply: Obd ii p0430
