intake manifold gasket replacment
Old September 25th, 2012, 8:09 AM
hunterjo's Avatar
Default intake manifold gasket replacment
Is there a place where i can come up with a procedure to replace the intake gasket on my 2001 suburban 5.3 motor. I think i have a coolant leak. smell coolant sometimes after driving a while.
any help would be helpfull.
Old September 25th, 2012, 10:05 PM
Are you getting water in your oil? Are you adding coolant constantly? If so you have a leak. Try Youtube. They have videos on most everything.
Old September 26th, 2012, 7:00 PM
Besides Youtube, there's always the Factory Service Manual.
Old September 26th, 2012, 8:41 PM
MDTAHOE's Avatar
There is no coolant running through the intake of a 5.3. It is not your leak.More than likely your water pump is leaking.
Old September 27th, 2012, 11:02 AM
hunterjo's Avatar
thanks for that info i will check it out better. what years do the 5.3 engine have with the leaking antifreeze problem at the intake gasket.
Old September 27th, 2012, 8:25 PM
MDTAHOE's Avatar
No 5.3 motors have problems with leaking coolant from the intake as no 5.3 have coolant in intake. The 5.7 had a coolant leaking from intake .
Old September 28th, 2012, 1:47 PM
hunterjo's Avatar
that is good to know. I will keep looking for the leak. thanks again to everyone who got back with me
hunterjo
gulfcoastjoe
May 4th, 2008 12:38 PM
gulfcoastjoe
April 28th, 2008 2:37 PM
gcahal_az
December 30th, 2007 6:35 PM
vfilby
December 28th, 2007 12:53 PM
JFBURB
December 28th, 2007 11:10 AM
Quick Reply: intake manifold gasket replacment
