Engine power reduced - service traction
These messages came up on my 2010 cobalt. Engine stalled 3 times on my way to Mountain View Chevy. $102.00 just to Find out what's wrong. So much for the warranty. Anyone have an idea what it may be?
Update- some wires were "rubbing together under the hood" and now it's gonna cost $350.00 to replace part of a harness. How is this not a manfacturing defect and why does it come out of my pocket?!!!
Official GM Rep
on
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Rjreidjr,
I'm sorry you are experiencing this issue with your vehicle. Would you please provide the last 8-digits of your VIN and the mileage on the vehicle, so I can look into this further for you?
I look forward to your reply.
Louis
GM Customer Service
Louis
GM Customer Service
Last 8 of the Vin - A7216465, mileage is 60k. To explain the "wires rubbing together" comment a little better, a harness feeds over the engine from the firewall area over the middle of the valve cover and rubbed on the front of the engine near the water inlet. The movement of the engine rubbing on the harness covering exposed wires and caused it to show a lot of codes and the engine power reduced message. I would suggest to others out there to check their vehicles for this defect as well. I do not race this thing around and its an automatic, it seems like the harness placement/routing should have been better thought out.
islandarmor
Avalanche
315
September 24th, 2023 12:19 AM
AllenC412
Equinox
16
April 29th, 2022 1:31 AM
thtgrl1985
Cruze
17
June 13th, 2020 8:21 PM
dcanada92
January 12th, 2016 8:46 PM
Dray
April 17th, 2014 9:43 PM
