Having problem getting to o2 sensor connector
Old December 15th, 2012, 2:28 PM
st francis's Avatar
Default Having problem getting to o2 sensor connector
HI Everyone,
I have a 2004 silverado with the 5.3 liter engine, It has 4 wheel drive and standard cab.
My problem is I am trying to change out the pre catalytic converter o2 sensors. The driver's side is giving me problems. I see the driver side sensor is in plain view but the connector is tucked up above the transmission. The drive shaft is in the way. I can only get one hand up there and I am am wondering how you were able to disconnect the old sensor plug and reconnect the new sensor plug? Any help is appreciated.
Thank you
Old December 15th, 2012, 8:08 PM
country_09's Avatar
Just pull read hard. It's just a push pin that holds it in. A real pain to get to. The new sensor has the push pin already on it so the old one will need to come out anyways
Old December 16th, 2012, 4:31 PM
st francis's Avatar
Thanks for responding. I was able to remove the plug from the frame but I still cant get more than one hand up there to disconnect the plug?
Old December 16th, 2012, 4:36 PM
kevinkpk's Avatar
I've never replaced one. My experieance with electrical connectors has been a push in, pull out with a latch. Can you feel a latch from the plug to the sensor? If so, you need to pop it it off the sensor, then pull the connector apart.
Old December 18th, 2012, 2:15 PM
st francis's Avatar
I just wish ther was enough slack to pull it down past the driveshaft so I can get both hands on it. My other option is to disconnect the driveshaft but I am worried I amopening a can of worms with all the rust on the driveshaft.
panzaa
June 22nd, 2014 5:06 PM
iosonolobo
March 31st, 2014 8:36 PM
aprentic3
Equinox
July 9th, 2012 5:21 PM
WhiteZ28
Camaro
March 18th, 2010 10:09 PM
jwalker54
August 9th, 2009 5:05 PM
Quick Reply: Having problem getting to o2 sensor connector
