07 Tahoe Power Liftgate Problem
Old December 15th, 2012, 9:10 PM
silverlx's Avatar
Default 07 Tahoe Power Liftgate Problem
My power lift gate has began to act up. First when it opened it would make a loud bang at tue very top just before it stopped. Then it refused to close when I punched the button. It would make noise for a second but wouldn't close automatically. Now it'll still open with power but when it opens all the way it begins to bang loudly at the top and jumps up and down several inches over amd over again and then closes very quickly. I'm not really sure where to start with this issue. Any suggestions?
Old December 15th, 2012, 9:18 PM
My guess is there some mechanical issues in the drive mechanism. Missing teeth maybe.
Old December 16th, 2012, 11:16 AM
might also consider replacing the hatch struts if they are original... they get weak over time and even more so when its cold... use extreme caution when removing them, the hatch is very heavy... use a 2x4 to support it and make sure its not supported by the glass for obvious reasons....
Old December 18th, 2012, 8:16 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> silverlx,
I’m sorry you are experiencing this issue with your Tahoe vehicle. The other posters offer some great suggestions. Another possibility is the Power Liftgate Module may need to be reprogrammed.
I recommend consulting with a certified technician for an official diagnosis and repair option(s).
Louis
GM Customer Service
Old May 3rd, 2015, 6:08 PM
pucduck's Avatar
I am having issues with my 2007 Tahoe power liftgate. It opens, near the top it makes grinding noises, then closes halfway, then all the way back to top, then closes itself all the way.
Scotiapilot
April 17th, 2015 2:35 PM
The_Stees
March 5th, 2013 8:20 AM
truckramrod
12
March 29th, 2011 7:35 PM
doo600
January 9th, 2007 4:57 PM
jbcobb
November 14th, 2006 7:18 PM
Quick Reply: 07 Tahoe Power Liftgate Problem
