Platform: Delta
Also Check out ChevyHHR.net
My HHR turn signal stick doesn't return when i put the signal
Old June 5th, 2013, 3:16 PM
fishingpro77's Avatar
Default My HHR turn signal stick doesn't return when i put the signal
Hello everyone.. nice to talkin' with all of you, here's the deal:
There's a issue on my 2007 HHR, when i put the turn signal (left or right), the stick doesn't return when the steering Wheel return to it right position (straight).. I need to set the stick manually.. does anyone knows if there's something wrong with the turn signal stick?.. if this issue can be fixed by myself or maybe i need to replace whole stick mechanism?..
Please, help me to find what's goin' on... i'll be happy to hear any suggestion or comment...
Old August 4th, 2016, 12:44 AM
mrmarkuSS's Avatar
It's in the switch itself. It's an easy removal. Once the switch is out take it apart carefully. Inside is a flat spring,which,over time,gets a bend in it,and the cam in the column no longer makes contact with the bent spring. Take the spring out,and reverse it,so the bend points towards the column,reassemble the switch and reinstall. Done,good as new! There's a YouTube video of it somewhere.
budbuzz350
December 5th, 2012 12:42 PM
EvansBlue
Ride of the Month
December 22nd, 2010 5:12 PM
jjhand
October 14th, 2009 6:40 PM
mytele
February 29th, 2008 9:38 AM
Quick Reply: My HHR turn signal stick doesn't return when i put the signal
