TrailBlazer 2002-2009
Rear lift gate/key fob issues
Old June 12th, 2013, 5:20 PM
thereseiam's Avatar
Default Rear lift gate/key fob issues
Hi all,
I just recently picked up a sweet Trailblazer. This truck is in amazing shape, even though it's an '02. Clean inside and out. I bought it knowing that the lift gate didn't work, but as I got to know the truck realized it's more than just that. The key fob doesn't function, the lift gate and rear window won't open, and the rear defrost and wiper doesn't work.
I first replaced the battery in the key fob. Then replaced the key fob. The truck itself does not respond when I try to program the key fobs, even though the key fobs have been tested (so I know that's not the issue).
Getting on the forums, I found that the Lift Gate Module was a common issue with the Trailblazers, so I ordered a used one (in order to avoid having to have it programmed at the stealership) and just installed that.
Nothing. Gah!!
Do I need to replace the Body Control Module? Something else?
Help!!
Much thanks~
Therese
Old March 13th, 2014, 8:42 AM
quincy25's Avatar
Default Having the same issue
Greetings,
Thanks for putting your information in regard to the tailgate issues. I have a 2006 and have had it since 22K miles. I have over 155K and it's still going strong but every now and then it has a mind of its own. Please let me know what was the fix to the issue.
Old March 14th, 2014, 4:04 AM
thereseiam's Avatar
If you open the back gate, at the top you will see a black plastic cover where the wires that run the back wiper, lift gate, etc. are. There are 5 wires in there, and 2 of them had broken. Very easy fix, I just had to strip the broken wires, reattach them, and tape them back together.
From what I understand this is a common issue since those wires are in the crack of the gate and even with the rubber protecting them they get wear and tear.
Hope this helps.
Therese
dolljason.p
July 25th, 2020 8:36 PM
hockeytrk
August 10th, 2019 1:34 PM
RJK
August 2nd, 2019 5:50 PM
TomS209
July 23rd, 2015 12:22 PM
chevykicksbut
October 23rd, 2010 12:32 AM
Quick Reply: Rear lift gate/key fob issues
