2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Installing Radio CD Player in 2004 Impala
Old March 18th, 2007, 8:09 PM
Greg O's Avatar
Default Installing Radio CD Player in 2004 Impala
I wasn't sure just where to post this, so I also posted it in the Audio Visual section.
I just bought a used 2004 Impala that came with a cassette radio. I want to install a factory radio with aCD player. They are available on Ebay for $50 to $150.My questions are, how hard is it to pull out the old radio and install the new one? I am not sure how these new dashes come apart. I am mechanical, but need some coaching.
Second,Are there any problems getting the anti theft code reprogramed?
Third, did some years have AM Sterio?
Thanks for your response,
Greg O.
Old March 27th, 2008, 9:52 AM
dryhorn2's Avatar
Default RE: Installing Radio CD Player in 2004 Impala
You can got to http://www.carstereoremoval.com/and buy instructions for $ 7.00 on how to replace unit. I do think the dealer has to reprogram.
Old March 27th, 2008, 5:24 PM
Dash removal is pretty straight forward. couple screw on both outer sides of the dash, I think a couple in the instrument cluster area, pop the cover from around the key cylinder off, put shifter all the way down, steering wheel all the way down, and starting at one side or the other, start pulling the dash off. Once off there are 3 7mm bolts holding the radio in.
When the new radio is in, it should work, but wil read calibrate everytime you cycle th power. Dealer needs to set-up the radio using a tech2.....5mins of work
Pomnuria
February 25th, 2014 10:15 AM
sorfian
April 19th, 2011 8:01 AM
adamant
February 15th, 2009 8:49 AM
Reyman
Audio/Visual Electronics
October 28th, 2008 6:59 PM
Greg O
March 27th, 2008 12:02 PM
Quick Reply: Installing Radio CD Player in 2004 Impala
