1994 CHEVY SUBURBAN K1500 5.7 (EGR VALVE)
Old May 31st, 2007, 9:01 AM
beatsie's Avatar
Default 1994 CHEVY SUBURBAN K1500 5.7 (EGR VALVE)
my 1994 k1500 5.7 chevy suburban service engine soon has been coming on.....took it to advance auto for computer check....i was told it was the egr valve can i put sheet metal under it to block it off and disconnect the vacuum line....or just disconnect the vacuum line...or should i just replace the egr valve....i was told they make a screen for some models but, i don't think they make one for mine....it has been drinking the gas....can anyone help me with this problem......p.s. i have also taken it off a cleaned it but it doesn't last very long..
Old June 1st, 2007, 7:17 AM
golfer's Avatar
Default RE: 1994 CHEVY SUBURBAN K1500 5.7 (EGR VALVE)
ummm.... no you shouldn't remove the EGR and block off the vacum .... if the EGR needs replacing replace it.
Old July 4th, 2007, 5:45 PM
350Suburban's Avatar
If you think it drinks gas now you'll die if you take the EGR valve off. If you take it off you'll eventually fun into several worse issues....such as detonation and fouling plugs. Replace it.
Theprofessor_18
January 25th, 2009 2:05 PM
simutant
September 30th, 2008 11:34 AM
slater
August 10th, 2008 8:14 PM
mpeel
February 5th, 2008 3:37 PM
cblu007
April 12th, 2007 1:20 AM
Quick Reply: 1994 CHEVY SUBURBAN K1500 5.7 (EGR VALVE)
