2001 Venture high idle speed
Old June 2nd, 2007, 5:01 PM
bwiles001's Avatar
Default 2001 Venture high idle speed
I have a 2001 Cehvy Venture van that has recently started idling at high speeds after being started. It will run for a few seconds at normal RPM then jump to a fairly high RPM. WHile driving, it will h old a speed of 45 MPH because of the engine speed. I am suspectng the idle air control valve but am not sure. Has anyone seen somethng similar. If so, where is the valve located so I can check it.
Old June 3rd, 2007, 10:15 AM
kil0's Avatar
Default RE: 2001 Venture high idle speed
x
Old June 4th, 2007, 11:34 AM
C3banjo's Avatar
I have the same problem with my '01 venture. Brought it to my mechanic just last week who found nothing during system scan and test drive. Itoccursduring hot weather (88+). Idle won't kick-down via accelerator but doesreset after turning vehicle off but resumes high idle after acceleration. This van has been an electronic nightmare - climate fan speeds fixed twice,rear air vent doors stuck, dash gets super hot with stereo use. The intake manifold gasket was replaced as well (overheating and fluid loss). Other than than that engine and drive train are solid. Vans accelerates, handles and rides really well and hauls 8 people and tons of gear.I hope we can get some help with that idle. It can't be healthy for the motor.
Old June 5th, 2007, 6:53 AM
mastar91169's Avatar
Mine has a similar high idle speed issue. I haven't found a solution yet so any advice is appreciated!
Old May 22nd, 2008, 7:04 PM
jimwoloschek's Avatar
I have experienced similar problems with our van. On warm days (+75 degrees), not only does it idle excessively fast but, in slow or stop and go traffic, the engine overheats and stalls. Frustrating on the expressway. Our mechanic as well as local Chevrolet dealership conclude there is no problem with the engine. Love the van but must find a solution to this problem.
Old May 27th, 2008, 2:56 PM
a4d
a4d's Avatar
My old F-150 had that problem i believe it was the IAC i really can't remember.
Old May 14th, 2012, 4:14 PM
womanofpraise's Avatar
My van has been idling back and forth also. It also hesitates gears. I found out that I needed a throttle position sensor. If you look this up it will show you the symptoms that happens when this goes bad. Idling is one of them. Hope this helps. The part itself cost around 40.00. You can find someone to put it in for you. Not sure how much labor will be.
in2pro
December 25th, 2020 11:34 PM
alka
Astro
March 29th, 2015 8:08 PM
cavingman
January 21st, 2014 11:23 AM
5:00 PM
Express & G-Series Vans
January 7th, 2012 11:38 AM
schwhack
May 28th, 2008 6:44 PM
Quick Reply: 2001 Venture high idle speed
