Lug nut torque specs
Old June 23rd, 2007, 10:53 PM
H07
H07's Avatar
Default Lug nut torque specs
Hi...new member here, great site by the way.
Just a quick questioncouldn't fine it inowners manual....what is the foot lb. torque spec for the wheel lug nuts?
Thanks!
Old June 24th, 2007, 12:37 AM
jazejeff's Avatar
Default RE: Lug nut torque specs
should be 100 pounds
Old June 24th, 2007, 2:24 AM
lagger's Avatar
I think the manual says 140
Old June 24th, 2007, 11:15 AM
H07
H07's Avatar
I guessed at 120 yesterday looks like I am pretty close.
Thanks
Old June 24th, 2007, 9:00 PM
ORIGINAL: lagger
[sm=exactly.gif]
Old June 25th, 2007, 11:25 AM
H07
H07's Avatar
Thanks...I will correct it to 140 !
Old October 28th, 2014, 2:14 PM
ral7772's Avatar
Since these answers show up no matter what Chevy you ask the specs for, the Lug Nut torque is listed in the owner's manual. For example: My search for Wheel nut torque for 2007 Impala came up with various opinions expressed about various models, from 100 - 140 ft lbs.
However, Owner's Manual says: 100 ft lbs (140 is the METRIC, NOT FT LBS)
Old October 28th, 2014, 4:59 PM
AZSCTACO's Avatar
Straight from the manual:
Application Capacities
English Metric
Fuel Tank
Regular 26.0 gal 98.4 L
Extended 1500 Series 31.5 gal 119.2 L
Extended 2500 Series 39.0 gal 147.6 L
Transmission Fluid
4L60-E Electronic Transmission 5.0 qt 4.7 L
6L80-E Transmission 6.0 qt 5.7 L
6L90-E Transmission 6.3 qt 6.0 L
Transfer Case Fluid 1.6 qt 1.5 L
Wheel Nut Torque 140 lb ft 190 Y
Old May 18th, 2017, 1:03 PM
Josh98's Avatar
Default 100 lbs ft
140 lbs ft is way to high straight from the owners manual it says 100 ft lbs it's 140 nm if that's what you use. DO NOT SET IT TO 140 ft lbs that's how you brake studs and send tires flying....
Old May 18th, 2017, 5:10 PM
2000 and newer sub and tahoe with 14mm wheel studs are 140 ft/lbs
1999 and older with 5 stud wheels may be lower
for the impala owner...cars use 12mm wheel studs and are torqued to 100ft/lbs
the point being...always check the service information.
jeff_bod
June 30th, 2011 7:45 PM
jen2swt
May 29th, 2010 8:45 AM
jusina
February 13th, 2010 8:29 AM
sixpack_sid
July 30th, 2009 8:56 PM
jcw1500wt
June 30th, 2008 3:33 PM
Quick Reply: Lug nut torque specs
