2019 Trax Air Condition Issue
Hello!
I went to turn on my air condition yesterday and no cold air. It had worked in the past. When I turn on the cold air button and circulate button, I am getting heat when temp control is in blue range. When I turn the heat control in the red zone it is actually less hot. This is really weird. What could be going on?
Thanks,
Kevin
Thanks,
Kevin
most lack of cold air concerns are from low ac charge ie leak or faulty blend doors...check for hvac dtc .
turn on the ac with the engine running. check that the ac compressor clutch is engaged. If not...have the system recovered...if the recovery amount is low...you have an ac leak.
if the compressor is engaged...feel the high and low side ac lines...aluminum tubes. the low side (large tube should be cold) the high side (small tube should be hot). if they are both near the same temp...have the system recovered to see if the recovery amount it low.
if the temps are hot and cold...the problem may be with the blend or mode doors in the hvac housing.
brjl
Silverado & Fullsize Pick-ups
November 20th, 2014 1:48 PM
